Disabling seatbelt sensor?
10 Nov 2023 08:17 #252049 by Pondboy
I always use seatbelts when driving, but when we get to our finca and have to get out to undo the chain at the entrance, we have a 100 metre drive down to the donkey corral. It is a pain to have to put the seatbelt back on for this, but the beeping is tiresome.
If I disconnected the sensor, will it create any other problems?
PB
Sent from my IN2013 using Tapatalk
10 Nov 2023 08:21 #252050 by saxj
Replied by saxj on topic Disabling seatbelt sensor?
Unplug the plug under the seat. I have not had any issues, but I am in South Africa, we don't have 99% of the safety stuff that is in the European versions - 2 Airbags and not much else
10 Nov 2023 09:24 #252051 by Roger Fairclough
If you disconnect the plug under the seat and bridge the gap in the socket with a 2 ohm resistor, the system will believe all is well, but it may not pass your local test examiner which will depend on the regulations in force.
Roger
10 Nov 2023 10:27 #252053 by Soeley
Replied by Soeley on topic Disabling seatbelt sensor?
I have one of these I use occasionally when laning.
amzn.eu/d/3qHffwE
10 Nov 2023 13:09 #252055 by Pondboy
Roger,
Thanks, that is what I need to do.
The Spanish ITV (MOT) just tests the seatbelts work (pull out & retract) and the fabric is undamaged.
PB
