Headlight Low / High Beam Switch Wiring under the Combination Switch
06 Nov 2023 18:04 #251999 by fordem
Now My issue. Is pretty hard to tell which wire is the one that carries the Low beam toggle signal which is the one I need to toggle in order to finish my project
You can either use a meter to see which wire "goes low" when you select low beam - OR - try my original suggestion - look at the back of the headlight bulb.
By the way, only one of the wires is red, the other one has a white stripe, so one is 'red", and the other is "red with a white stripe", the color of the insulation is used to identify which circuit the wire is a part of.
Time to create page: 0.193 seconds
