Front axle swivels pitted and corroded
13 Oct 2023 12:25 #251382 by Terry
I have a 2006 Jimny and at the last service my garage told me the front axle swivels were leaking oil and corroded. They tried to be helpful but advised me I would need to source replacement parts myself and were unable to say if I needed to find a complete replacement axle or if the swivel was a separate unit. Is anyone able to give me a bit of guidance as to whether the axle and swivel are one combined part and what sort of cost I should be looking at? Many thanks for any advice you have
13 Oct 2023 12:50 #251383 by yakuza
Inside the swivel there should be grease and inside the axle there is oil. A simple shaft seal should be changed and at the same time I would inspect and most likely change the king pin bearings and swivel seals.
Rust on the swivel is not a show stopper, can be sanded down and painted as well.
All these parts are easy to come by and serviceable
The following user(s) said Thank You: Terry
13 Oct 2023 12:57 #251384 by yakuza
This is a Job most of us do ourselves, so any good garage should be capable. Still I have heard many having bad experiences or strange soulutions been chosen, or not all parts have been changed.
13 Oct 2023 13:28 #251389 by Terry
Thanks for getting back to me. I omitted to say that it was leaking oil so that ties in with your advice. Thank you
13 Oct 2023 14:59 #251393 by DrRobin
The large swivel seal is just there to keep the dust out, it also keeps the heavy waterproof grease in to a certain extent.
If the swivels are pitted the large seal won't work as well as it should, but it doesn't do a great deal anyway so as Yakuza says, just clean up the existing swivel.
The oil leak is coming from the shaft seal, inside the swivel, it's easy enough to change once the hub is off. If the seal has gone the king pin bearings have probably also gone so change them both at the same time and fit a new large seal.
Martin sells the king pin bearings, large swivel seal and grease, look in the BigJimny store here www.bigjimny.com/store/ or in the banner at the top of the page. He is competitive on price against other online retailers and a lot cheaper than Suzuki.
It's a fairly easy job to do at home or for a garage. Tip, buy new swivel seal bolts, mine were all rusty and they don't cost much.
The brake caliper bolts and one set of king pin bolts on mine were very tight, they did come out but took a bit of a stern talking to with a good fitting socket and large breaker bar or hammer, depending what would fit in.
Robin
13 Oct 2023 15:30 #251397 by jackonlyjack
Rub them down and paint with por15 paint
Then rub and paint 3 more times with same paint
The kit with smallest tin of por15 is more than enough
I did mine year's ago still going strong
Time to create page: 0.242 seconds
