Add ABS on Jimny its possible?
11 Oct 2023 03:48 #251340
by crynof
Add ABS on Jimny its possible? was created by crynof
Hello! I have a 2013 Jimny JLX JB43. According to the technical sheet I found online, it should have ABS, but upon checking my Jimny, it doesn't have it. Is it possible to add it myself?Is it very difficult?
Best regards!
Best regards!
- Thank you received: 2004
11 Oct 2023 04:53 #251342
Replied by Lambert on topic Add ABS on Jimny its possible?
If you definitely don't have it then it's going to be easier to find a model with it. You need a pump, pipes, hubs with sensor locations, sensors, wiring and control modules. Not practical to retrospectively install.
- rogerzilla
11 Oct 2023 13:56 #251350
by rogerzilla
Replied by rogerzilla on topic Add ABS on Jimny its possible?
The ABS control module also talks to the 4WD module, so it's possible other electronics would need to be changed. As Lambert says, not practical. Drive safely!
- Thank you received: 706
11 Oct 2023 17:18 #251355
Replied by jackonlyjack on topic Add ABS on Jimny its possible?
The following user(s) said Thank You: crynof
12 Oct 2023 00:28 #251359
by crynof
Replied by crynof on topic Add ABS on Jimny its possible?
I understand, I thought it could be easier, like changing the brake pump for one with ABS and installing the sensors.
I will settle for my vehicle and drive more carefully simply, then I will upgrade to a newer model.
Thank you!
Thank you!
Time to create page: 0.101 seconds
