2004 Jimny Gear knob replacement
- Schmidt
02 Oct 2023 12:57 - 02 Oct 2023 12:58 #251144
by Schmidt
2004 Jimny Gear knob replacement was created by Schmidt
Hi Guys
I was sure this was going to be as easy as 1-2-3.
I have purchased a new gear knob and thought this would be a 2 minute job.
I can't twist the original gearknob off. After heating it with a heat gun i managed to get the "rubber" itself of, but the hard plastic shell is still on there.
I just want to be absolutely sure that all Jimnys have threaded stick. Would be quite annoying if I break the original gearknob while taking it off only to discover that I can't get the new one on
I guess I need a bigger set of stilsons or just more power to get it off
I have found other topics on this, but just want to be absolutely sure that there are not different knobs on different models
Last edit: 02 Oct 2023 12:58 by Schmidt.
- Thank you received: 679
02 Oct 2023 13:04 #251145
Replied by DrRobin on topic 2004 Jimny Gear knob replacement
My 2011 was screw on and yes it took a bit of moving as I think they are glued in place.
I assume they were all screw on, but someone with a 2004 will know for sure.
02 Oct 2023 15:09 #251146
Replied by jackonlyjack on topic 2004 Jimny Gear knob replacement
Yes threaded
- Schmidt
02 Oct 2023 17:08 #251149
by Schmidt
Replied by Schmidt on topic 2004 Jimny Gear knob replacement
Cool - Thanks guys!
More heat, bigger stilsons and maybe a trip to the gym and I hope I'll make it
- Thank you received: 2006
02 Oct 2023 20:06 #251150
Replied by Lambert on topic 2004 Jimny Gear knob replacement
My old old 54plate just unscrewed as did all the others. I am built like a gorilla though.
The following user(s) said Thank You: Schmidt
Time to create page: 0.170 seconds
