Tire size and recommendations
3 years 1 month ago #250981 by Dazcush
Hi guys,
I have recently bought a 2002 Jimny and am looking to get a new set of tires for it for the winter in Ireland. I will be using it for a daily commute (only 10km) and also for getting to mountain biking trails 2/3 times a week so plenty of fire roads.
It is completely standard and I am not planning on getting it lifted for the moment.
The current tires are 205/70r15. From reading some posts on Big Jimny I believe the biggest tires I can fit without a lift or changing things up too much are 215/75s?
I'm thinking of BFG All Terrains, as I don't think I need MT's? Are there any alternatives that people are using / would recommend or are the AT's. solid shout? And if so... what size?!
Cheers,
Darragh
3 years 1 month ago #250982 by DrRobin
BFG KO2 in 215/75 are a good choice and the Maxxis Worm-drive in 215/75 is very similar, but usually a bit cheaper.
I run Maxxis 215/75 and confirm they fit without a lift or wheel arch trimming.
I don't think BFG or Maxxis are available in 205/70 but I like the extra width and chunky tread pattern of the larger tyre.
I also have a set of Hancook Dynapro in 205/70, they look good and did have Geolandars in 205/70, out of the two the Geolandar was more of a road tyre with good off-road, but the Dynapros were possibly slightly better off road and about the same on road. There are plenty of other good tyres in 205/70, butmy experience is limited to Hankooks, Geolandar and of course Duellers (which is what came on the vehicle).
The Maxxis and BFGs are probably much better off road, on road, I don't really notice much difference to the Hancook or Geolandar, but I am sure they will be slightly more noisy and ride probably isn't quite as good.
I spend most of my time on road, but still like the look of the Maxxis and especially the performance when off road.
Robin
The following user(s) said Thank You: Dazcush
3 years 1 month ago #250986 by 300bhpton
I'll put another vote for the Maxxis Wormdrives. I have them fitted to two vehicles, one being my Jimny and I've done maybe 15,000 miles on them. My brother has the BFG KO2s on his 90. I like them too, but I can't see where the extra money is. If I was buying again I'd still go for the Wormdrives, even if the BFGs cost the same.
3 years 1 month ago #251096 by Dazcush
Thanks for all your info. I will check and see what's available and go from there!
3 years 1 month ago #251170 by Dazcush
Are both of these tires suited to the standard 5.5Jx15 ET5 rims??
3 years 1 month ago #251175 by DrRobin
Yes. 215 is the widest tyre they recommend for 5.5 wheels, I believe.
I confirm 215/75 will fit standard wheels and clear the wheel arches.
Time to create page: 0.092 seconds
