Death wobble
17 Sep 2023 12:19 #250848
by volpin
Death wobble was created by volpin
Hi to all, i have death wobble on my 2019 jimny after bending tie rod and steering dumper breakage. Jimny is lifted and run 33s. Death wobble appears from 50 to 60 kmh and more when i breaking and go from 40 to 0 speed.
i straigthining my tie rod and i'm going to do a front alignment next days. I check track bar, drag link and wheel bearing for play and all seems to be good.
do you think i solve with alignment and stwering dumper replace? What i can still check?
thanks to all
thanks to all
17 Sep 2023 15:48 #250849
by facade
Replied by facade on topic Death wobble
More than likely the new damper will fix it. Suzuki have been chasing Death Wobble for years, with bulletins about shimming. I suspect reducing wobble is the reason for fitting the damper in the first place.
17 Sep 2023 16:51 #250851
by volpin
Replied by volpin on topic Death wobble
Maybe can be kingpin bearings? I have 25k km on it
17 Sep 2023 17:14 #250853
by facade
Could be, it is an accumulation of things, like slack bearings and the 33s, but you say the wobble appeared after you broke the damper, so an unbroken one should bring it back under control.
17 Sep 2023 18:37 #250855
by volpin
Damper fail and tie rod bent
19 Sep 2023 15:22 #250896
Replied by jackonlyjack on topic Death wobble
Warped discs maybe
I run 32's and have dyna beads for balancing
Time to create page: 0.171 seconds
