Oil for Gen 4 Jimny
27 Oct 2023 08:00 #251787 by Busta
Replied by Busta on topic Oil for Gen 4 Jimny
It's interesting that you have decided the specified oil is not to your liking. Please, if you could run that oil in multiple engines for 150,000 miles in all conditions then strip the engines, check everything is still within tolerance and report back with your findings? Then other owners will be able to consider it as an alternative option for their engines.
  • rogerzilla
27 Oct 2023 08:27 #251788 by rogerzilla
Replied by rogerzilla on topic Oil for Gen 4 Jimny
Suzuki are trying to get the lowest possible CO2 g/km and highest mpg in standard tests.  Owners don't need to do that.
27 Oct 2023 10:54 #251793 by Busta
True, but they have also tested that it does the job required e.g. lubricating the engine efficiently for the life of the vehicle. They aren't just winging it with what they think they can get away with.
Whilst I'm not against people tinkering, this idea that you should change things simply because it doesn't look/feel right to you is silly.
Also:Under the Road Vehicles (Construction and Use) Regulations (Regulations 61(7) and 61A(3)) and the Road Traffic Act 1988 (Section 42) it is an offence to use on a road a vehicle which has been modified in such a way that it no longer complies with the air pollutant emissions standards it was designed to meet.The potential penalties are £1,000 for a car and £2,500 for a van, lorry or bus.
  • rogerzilla
27 Oct 2023 13:40 - 27 Oct 2023 13:40 #251800 by rogerzilla
Out of interest, is the 1.5 engine direct injection, and is the 0W16 oil API SN or SP?  The Ecstar 0W20 is SN but the latest SP has some advantages for GDI engines.  I can't find a spec for the 0W16 anywhere.
Last edit: 27 Oct 2023 13:40 by rogerzilla.
27 Oct 2023 14:57 #251807 by BigJimy
Replied by BigJimy on topic Oil for Gen 4 Jimny
the Motul 5w40
27 Oct 2023 17:40 #251821 by BigJimy
I believe its a direct injection. My post above for what I put. And here is some info for the 0w16
ecstareurope.com/pdf/Ecstar_product_catalog_EN.pdf
Time to create page: 0.366 seconds
