Oil for Gen 4 Jimny
02 Nov 2023 00:19 #251910 by Chops
Replied by Chops on topic Oil for Gen 4 Jimny
Out of interest, is the 1.5 engine direct injection, and is the 0W16 oil API SN or SP?  The Ecstar 0W20 is SN but the latest SP has some advantages for GDI engines.  I can't find a spec for the 0W16 anywhere.
I believe its a direct injection. My post above for what I put. And here is some info for the 0w16
ecstareurope.com/pdf/Ecstar_product_catalog_EN.pdf
Considering it doesn't have a high pressure fuel pump I am very, very confident it's still a port injection motor. Turbo Swift Sports (K14C) motors are direct injection, though
  • rogerzilla
02 Nov 2023 09:25 #251911 by rogerzilla
Replied by rogerzilla on topic Oil for Gen 4 Jimny
Another reason to buy a Jimny - port injection is much less trouble and creates less nasty stuff in the exhaust.
21 Nov 2023 01:16 #252253 by BigJimy
Replied by BigJimy on topic Oil for Gen 4 Jimny
I would delete the catalysators, no brainer too, but cannot find inox manifold on the Ali, or some other place
21 Nov 2023 08:09 #252256 by mlines
Replied by mlines on topic Oil for Gen 4 Jimny
It looks like port injection to me. The actual Suzuki description is "multi-point fuel injection system located above the inlet valve". Visually the injectors are screwed into the head directly above where the intake manifold bolts to the head. As it is above the inlet valve, this would be port injection to me.
21 Nov 2023 14:16 #252273 by Wailin
Replied by Wailin on topic Oil for Gen 4 Jimny
Busta post=251793
True, but they have also tested that it does the job required e.g. lubricating the engine efficiently for the life of the vehicle. They aren't just winging it with what they think they can get away with.
Whilst I'm not against people tinkering, this idea that you should change things simply because it doesn't look/feel right to you is silly.
Also:Under the Road Vehicles (Construction and Use) Regulations (Regulations 61(7) and 61A(3)) and the Road Traffic Act 1988 (Section 42) it is an offence to use on a road a vehicle which has been modified in such a way that it no longer complies with the air pollutant emissions standards it was designed to meet.The potential penalties are £1,000 for a car and £2,500 for a van, lorry or bus.
Are you actually implying that someone using a slightly different grade of oil is committing an offence and should be fined? Wow
21 Nov 2023 18:36 #252278 by Busta
Replied by Busta on topic Oil for Gen 4 Jimny
No I'm not implying it.
Time to create page: 0.204 seconds
