Cranking but no start
14 Sep 2023 08:11 #250803
by NiklasH
Cranking but no start was created by NiklasH
Hi
I have a jimny -99 that won't start, doesn't get any signals out of the ECU box.
Have measured the input signals that can be measured and they are correct.
Has taken ECU, key and immobilizer from another -99 but it does not send out any signals to ignition, injection or tachometer.
Replaced the cam position sensor and those signals are correctly entered into the ECU.
Have no error codes and have run out of ideas how to continue troubleshooting.
14 Sep 2023 08:43 #250805
Replied by yakuza on topic Cranking but no start
Welcome to the forum
Checked grounding / earth / minus on the ECU?
Fuses?
dashboard cluster, what lights work and wich do not when ignition on?
The dash cluster is wired into the ECU so some grounding in the harness comes from there. Cluster print boards can fail also.
Fuses?
14 Sep 2023 10:30 #250809
by NiklasH
Replied by NiklasH on topic Cranking but no start
Thanks been here for a while but didn't register me
Have checked all ground and + to the ECU and they are correct.
All fuses are intact
I have changed the dashboard cluster from the working car and it is the same lamp that lights up on both cars
Time to create page: 0.182 seconds
