Smoky Jimny
07 Sep 2023 10:09 - 07 Sep 2023 10:12 #250702 by yakuza
Replied by yakuza on topic Smoky Jimny
it gets that ever so often, but I'm 53 years old :)
Edit: And the nearest local dual carriage way is only 5 hours from here haha. (If not counting the very steep uphill in the under sea tunnel)
Last edit: 07 Sep 2023 10:12 by yakuza.
  • rogerzilla
07 Sep 2023 12:37 - 07 Sep 2023 12:38 #250706 by rogerzilla
Replied by rogerzilla on topic Smoky Jimny
If the PCV breathers are blocked, it can do funny things - in theory the crankcase should normally have a small through airflow from the clean air intake tract, into one side of the rocker cover, and out to the intake manifold (lower pressure sucks it through because of the presence of the throttle valve). At higher loads, blow-by increaes crankcase pressure and it only blows one way.
If the system is clogged, oil mist gets forced where it shouldn't, you get oil leaks, or odd idling problems because the metered airflow is no longer correct.
As it's only a couple of hoses and a ball valve, it's easy enough to check and flush with carb cleaner if necessary.
Last edit: 07 Sep 2023 12:38 by rogerzilla.
07 Sep 2023 18:22 #250711 by Lambert
Replied by Lambert on topic Smoky Jimny
The more I learn about where you live the more I think I should learn Norwegian and emigrate! But then I remember the laws and rules you have to endure when you want to modify your Jimny.
Time to create page: 0.219 seconds
