Smoky Jimny
06 Sep 2023 11:37 - 06 Sep 2023 11:39 #250687
Smoky Jimny was created by yakuza
My nice Danish friends pointed out to me that my Jimny released some smoke after going downhill using the engine and low gears to reduce speed down the many hills on our trip a few weeks back. The engine oil level has gone from full to low on the 3000km's since before the trip and the last oil change, so I am thinking it could be the valve stems leaking. I have used a Castrol fully synthetic oil so will try to change it soon for something better, but i fear the inevitable job of doing the stem gaskets. Is this common on the m16?
I did run it too long on the oil change before this, did not make a note of the km spent on that oil change, but could be two years and 16000km's. Regret not being nice enough to the engine.
Last edit: 06 Sep 2023 11:39 by yakuza.
06 Sep 2023 14:26 #250689
by Dorse
Replied by Dorse on topic Smoky Jimny
A quick compression test will tell you if it's the stem seals or something more serious. You can do the seals without taking the head off. Disconnect the battery, remove the rocker cover , then one cylinder at a time take the sparkplug out, drop piston to BDC, and patiently feed 2 meters of 6mm flexible rope in through the sparkplug hole, bring the piston back up towards TDC until the engine locks, your valves for that cylinder are now locked in situ by the rope so you can now replace the seals without the valves dropping. A good quality nylon rope is best as it won't fray.
07 Sep 2023 05:22 #250698
Replied by yakuza on topic Smoky Jimny
Rope is a good tip, sounds way easier than a air pressure tool.
Car still runs very well by the way. it pulls off uphills way better then other jimnys even with my trailer.
Will try to borrow a compression tester to rule out the piston rings and valves, good tip, thanks!
- rogerzilla
07 Sep 2023 06:47 #250699
by rogerzilla
Replied by rogerzilla on topic Smoky Jimny
Check the easy stuff first - are the PCV pipes clear, and is the one-way valve working?
07 Sep 2023 07:55 - 07 Sep 2023 08:02 #250700
Must admit i do not fully understand their function, and they where very clogged and then cleaned when doing the engine swap.
Will check!
Do they clog more from driving more with low rpms? The car now has way better low rpm torque so do not need to shift down as much as before and generally it is in fifth from 60kmt and up. Even overtaking often in fifth. Do rev it up and drive "hard" as well, but mostly day to day is in fifth gear. and my long drives this summer with a trailer and loaded with camping gear as well..
Could the m13 ECU and the m16 engine also make the m13 valve and pipe clog more easily?
Aha! Yes I was wondering about this, if they could play a part in regulating the pressure making the engine suck more oil in.Check the easy stuff first - are the PCV pipes clear, and is the one-way valve working?
Will check!
Last edit: 07 Sep 2023 08:02 by yakuza.
- Thank you received: 2001
07 Sep 2023 09:33 #250701
Replied by Lambert on topic Smoky Jimny
I can't add much to diagnosis but I do firmly believe in the advantages of an Italian tune up, aka giving it opportunity to visit the redline in the first 3 gears every so often. A good thrash down the local dual carriage way works wonders.
Time to create page: 0.225 seconds
