Catalytic converter problem
20 Aug 2023 15:50 #250403
by Vandoni
Catalytic converter problem was created by Vandoni
So, I've removed the catalytic converter as a part of the power mods done to the car, and I can hear it burble when I let off the throttle or keep it very lightly pressed and decelerate, but no flames come out and no pops or bangs, (the ECU is stock).
I noticed a pipe that's wider than normal behind where I put the decat pipe, what is it?
photo for reference, the arrow is the flow of exhaust gases
- ZanJim97
22 Aug 2023 15:02 #250447
by ZanJim97
Replied by ZanJim97 on topic Catalytic converter problem
So that would be the resonator, a quick google search - "The resonator is a complement to the muffler in that it removes high-pitched noises along with annoying hums and buzzes."
I would perhaps look at a better muffler or new muffler, to slightly increase the back pressure. Pipe diameters also play a role.
22 Aug 2023 17:27 #250449
by Vandoni
Replied by Vandoni on topic Catalytic converter problem
The muffler is good enough I think, I don't like back pressure, the car seems to run a lot better without restrictions.
also thanks for the answer!
