oil filter/mains rattle query
- dafyddcoch
07 Aug 2023 06:41 #250129
by dafyddcoch
oil filter/mains rattle query was created by dafyddcoch
Hi all. Our 2022 M!£A engined jimny has done around 123k.and has been well maintained. However, after the last oil-change, at which I used a Bosch oil filter, and 10/40 semi syn. oil, I have the dreaded mains rattle for a nano-second upon startup. Coincidence? Or, do some oil-filters still not have the shut-off valve in them. Should I try a genuine filter? If the mains are now wearing, I guess I'm in for an expensive bill as at that mileage, we may as well have a full crank re-grind do the big ends as well. But of course, we may as well stick a set of rings in and overhaul the head at the same time but I don't have the facilities or the health to do that anymore. Anyone know a friendly Suzuki bod in North Wales?
Diolch/Thanks
Diolch/Thanks
07 Aug 2023 10:44 #250135
by Busta
Replied by Busta on topic oil filter/mains rattle query
I've never heard of a shut off valve in a Jimny oil filter. I use whatever filter is cheapest on eBay and have had no such issues. How do you know it's the main bearings rattling? I wouldn't expect any major wear at that mileage, however replacement engines are around £150 and readily available so it's not an expensive fix.
07 Aug 2023 11:02 #250138
by gv42
Replied by gv42 on topic oil filter/mains rattle query
Hi Where abouts are you in north wales
- dafyddcoch
09 Aug 2023 10:30 #250177
by dafyddcoch
Replied by dafyddcoch on topic oil filter/mains rattle query
Hi we live in the hills above Caernarfon. Thans/Diolch
- dafyddcoch
09 Aug 2023 10:36 #250178
by dafyddcoch
Hi and thanks for you response.
"How do you know it's the main bearings rattling?"
Usual symptom of short rattle upon starting and nano-second delay in oil light going out. Big ends knock, mains rattle. etc etc.
Thanks again
Thanks again
09 Aug 2023 11:10 #250179
by fordem
It's generally referred to as an "anti-drain-back" valve and usually takes the form of a rubber ring visible through the six holes that form the inlet to the filter.
Like you I would not expect the engine in a 2022 Jimny to have enough wear for the mains or the timing chain to rattle, but, since a 2022 Jimny would/should have a K15 engine, not an M!£A, I'm wondering if there is more than one typo in there.
Typically there is enough residual oil in the mains & big ends to allow for a start up without rattle, I can drain & refill the oil on pretty much any of my Suzukis and there is no rattle for the several seconds it takes to refill the filter, so that engine would have to have some significant wear.
Replied by fordem on topic oil filter/mains rattle query
Time to create page: 0.157 seconds
