Air temp sensor
06 Aug 2023 16:43 #250123 by Vandoni
Air temp sensor was created by Vandoni
What would happen if the air temp sensor were to be left out of the intake tube and dangling in the engine bay? (2000 Jimny M13A) would the engine run leaner because of the higher temperatures in the engine bay compared to the inside of the intake?
07 Aug 2023 07:42 #250130 by DrRobin
Replied by DrRobin on topic Air temp sensor
It could run lean, warm or hot air is less dense and therefore contain less oxygen. As such your eco might lean the mixture to compensate.
However, if your Lambda/O2 sensor in the exhaust is working correctly this should pull the mixture back. This will create a high fuel trim value and might spit out an error code if it goes too far.
Depending where the sensor is dangling there might not be too much difference between engine bay and air intake temp, especially whilst moving.
Robin
The following user(s) said Thank You: Vandoni
08 Aug 2023 19:04 #250172 by Vandoni
Replied by Vandoni on topic Air temp sensor
yeah i thought so, to be sure i got the sensor in the filter in some way, the car seems a little happier, not very noticeable but still better than having it dangle around.
another thing, i'd like to change the color of my gauge lights, but i donìt know what kind of bulb it is or if i should get some LEDs
Time to create page: 0.144 seconds
