Transfer box switch replacement.
- Woodsman
29 Jul 2023 16:56 #250031
by Woodsman
Transfer box switch replacement. was created by Woodsman
Hi all, can anybody give me some advice/info on replacing transfer box 4wd switches. My switch at the rear of the transfer box (2 black wires grey plug) has a broken wire and not enough to solder back together. If I just replace the switch will I need to drain transmission first?
ANy help would be great, thankyou all.
- lesgrandepotato
- Elite Member
- Thank you received: 57
29 Jul 2023 17:16 #250032
by lesgrandepotato
Replied by lesgrandepotato on topic Transfer box switch replacement.
I hazard it won’t be a problem. But a quick squiz at its location relative to the fill point will tell all.
- Woodsman
29 Jul 2023 17:37 #250033
by Woodsman
Replied by Woodsman on topic Transfer box switch replacement.
Thanks for the reply, didn't think about that, cheers
29 Jul 2023 20:23 #250035
by bryn
Replied by bryn on topic Transfer box switch replacement.
Jack the car up so as to move the transfer oil away from the switch. Be ready with the new switch and undo the nut/switch and quickly replace old with new. You may need to stick your finger in the hole etc between swapping over to prevent the oil coming out. No need to drain down.
Note
There’s a free moving ball baring within the switch housing that that must remain in there.
Bryn
Note
Bryn
- Woodsman
31 Jul 2023 07:37 #250058
by Woodsman
Thankyou very much for the heads up, regards the ball bearing. Very much appreciated.
Cheers
Cheers
Time to create page: 0.148 seconds
