OEM wheel specs?
26 Jul 2023 14:34 #250006 by Vandoni
OEM wheel specs? was created by Vandoni
I have a 2000 Jimny, M13A, stock wheels are 15" and tyres are the stock 205 wide ones, what are the other specs of the wheel?
26 Jul 2023 15:09 #250007 by DrRobin
Replied by DrRobin on topic OEM wheel specs?
15" wheel, 5.5" wide, ET05 to fit 205x70r15
The other information is 5 stud on 139.7mm diameter with a 108.7mm bore
You can go up to 215x75r15 on these rims without issue
The following user(s) said Thank You: Vandoni
27 Jul 2023 10:55 #250016 by Vandoni
Replied by Vandoni on topic OEM wheel specs?
Thank you so much! I'll see if it legal to go with 215s and if it's useful both on road and off-road.
The following user(s) said Thank You: TICKDOG
27 Jul 2023 12:22 #250017 by DrRobin
I run Maxxis Worm-drive in 215/75r15, the other popular make is BF Goodrich. Both legal here in the UK (not sure about Italy) and both fit on the original rims without issue.
215/75r15 is about the largest tyre you can fit in without having to trim wheel arches, the gap between tyre and wheel arch is visibly smaller than 205/70. The tyres are about 4% bigger, so your speedo/distance will read about 4% lower.
Speedo's accuracy read anything up to 10% high, so you should still be OK. My speedo now agrees almost exactly with the GPS so it must have been reading about 5% high before, just watch out for the speed traps.
Robin
Time to create page: 0.147 seconds
