Manual Hubs install
- Thank you received: 11
06 Jul 2023 21:31 #249768
by JAGtheman
Julian
2008 Gen 3 Manual
Being completely revitalised
Manual Hubs install was created by JAGtheman
This evening after engaging 4wd, it failed to engage and now I have a flashing / illuminated 4wd symbol on the dash. I will now opt for manual hubs as I hear horror stories of failing vacuum systems. Before I order the hubs from Lambertengineering I have a few questions I hope the experts can help me with:
Vehicle is a shiny, new looking 2008 Gen 3 manual, advanced stage of refurb back to like new.....
Help and comments much appreciated!
Julian
- Can I fit manual hubs with the 4wd light illuminated on the dash?
- Do I need to bridge wires somewhere? (conflicting info on this point ... for sure I dont want any illuminated/flashing lights on the dash)
- If I have to bridge wires, this is where I get lost... can someone explain what, where and how I must do this?
Julian
Julian
2008 Gen 3 Manual
- Thank you received: 2005
07 Jul 2023 03:25 #249771
Replied by Lambert on topic Manual Hubs install
All I have done to stop the flashing light is seal off the rubber vacuum lines at the solenoids under the battery tray, being a shepherd I just used nails of a suitable diameter and zip tied them together to stop them moving. Works fine.
07 Jul 2023 08:47 - 07 Jul 2023 08:47 #249775
by facade
Replied by facade on topic Manual Hubs install
If you look at the vacuum solenoids under the battery, there is a round vacuum switch. Join the wires together with a scotchlok.
Then you can remove the rubber vacuum feed from the manifold to the solenoids, and cap the manifold end spigot.
However, the original system relies on the seal in the wheel bearing ( -> 2WD) and the one between the CV joint and the hub (-> 4WD) so you may actually have failing swivel bearings pulling the CV out of alignment and causing the problem.
Leaving the system in place and plugging the vacuum pipes works provided that the original fault wasn't a sticking solenoid valve causing a loss of vacuum, or damage to the pipe from manifold to the solenoid valves. The solenoid valves get water inside if you go through water much over the axle and this makes them stick half open when they return under spring pressure- venting the vacuum tank.
Last edit: 07 Jul 2023 08:47 by facade.
08 Jul 2023 08:08 #249783
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic Manual Hubs install
This may help:
- Thank you received: 679
08 Jul 2023 18:21 #249787
Replied by DrRobin on topic Manual Hubs install
The vac lines on my Jimny were blocked, so I got a solid green, but the hubs didn’t engage. I just plugged the vac line at the solenoid with a rubber bung and put a cable tie round, but a nail works just as well. I then fitted manual hubs.
If your lines are shot, just plug at the solenoid as well and if you are worried about the hubs, just plug thos as well.
I did intend to buy some flexible vac pipe and just replace all of the lines as there are several joints and a mixture of steel and flexible pipe in the Suzuki setup.
Robin
Robin
08 Jul 2023 19:23 #249788
by JAGtheman
Julian
2008 Gen 3 Manual
Replied by JAGtheman on topic Manual Hubs install
Thanks Lambert & Dr.R... as always!
Sir Facade!... you slipped a small comment that makes me go ooooops... "However, the original system relies on the seal in the wheel bearing ( -> 2WD) and the one between the CV joint and the hub (-> 4WD) so you may actually have failing swivel bearings pulling the CV out of alignment and causing the problem.".....
How would I know if this is the case?. The vehicle runs beautifully, no off road adventures in past 4 years, no funnny noises, smells or smoke. What would I look for? (Am now on hold till I cover this...!!)
JAG
JAG
Julian
2008 Gen 3 Manual
Time to create page: 0.178 seconds
