Rear suspension bottoming out on rough roads.... where to start?
04 Jun 2023 17:09 #249418
by Manxman
Replied by Manxman on topic Rear suspension bottoming out on rough roads.... where to start?
There's no spacers in there currently, but its not a bad call, spacing up the back end to level it out and then go from there. Cheers.
The following user(s) said Thank You: jackonlyjack
05 Jun 2023 09:01 #249427
by Busta
Replied by Busta on topic Rear suspension bottoming out on rough roads.... where to start?
30mm lift in the rear is roughly what you get if you put front springs in the rear, which in itself isn't a bad mod but it's no good if you need more clearance. I'd ditch the Pro Comp shocks straight away. They are universal fit designed for much heavier vehicles than the Jimny and always result in an unpleasant ride.
Time to create page: 0.331 seconds
