Replacement Body Panel Clips
- Rabid Rhino
- Elite Member
- Thank you received: 33
19 May 2023 10:27 - 20 May 2023 06:26 #249173
by Rabid Rhino
Replacement Body Panel Clips was created by Rabid Rhino
I need some.
Years ago someone recommended Toyota but I can't find the post with the photos.
I bought a load but they've been lost in moves ir storage and too old to be in my ebay purchase history.
Will these do ?
Will these do ?
Last edit: 20 May 2023 06:26 by Rabid Rhino.
- Thank you received: 679
19 May 2023 13:12 #249177
Replied by DrRobin on topic Replacement Body Panel Clips
Martin sells the genuine ones in the BigJimny store
www.bigjimny.com/store/search.html?searc...el+clips&_a=category
Robin
Robin
19 May 2023 17:48 #249185
by fordem
Replied by fordem on topic Replacement Body Panel Clips
It depends on where you're putting the clips - those look like the style that hold the door cards to the door.
- Rabid Rhino
- Elite Member
20 May 2023 06:29 - 20 May 2023 06:31 #249190
by Rabid Rhino
Replied by Rabid Rhino on topic Replacement Body Panel Clips
They're for holding the exterior door plastics & wheel arches.
Whoever it was, recommended Toyota over Suzuki.
I'm thinking the ones with the little rubber/foam gasket might put a little extra tension & cushion on the fitting.
Last edit: 20 May 2023 06:31 by Rabid Rhino.
20 May 2023 13:23 - 20 May 2023 13:29 #249195
Replied by jackonlyjack on topic Replacement Body Panel Clips
The ones pictured above may fit the sill/outer door cover
But you will need these toyota ones for wheel arches
ebay item number 371405333825
Last edit: 20 May 2023 13:29 by jackonlyjack. Reason: Picture
- Rabid Rhino
- Elite Member
20 May 2023 21:12 #249205
by Rabid Rhino
They're the ones !!!!
Cheers.
Cheers.
Time to create page: 0.173 seconds
