Steering lock query
19 May 2023 08:29 #249170 by Paul4A
Steering lock query was created by Paul4A
Are there any known issues with the ignition barrel of a gen 3 Jimny?
Today I couldn’t get the ignition key to turn. I tried in and out several times,  turning the key and wiggling it.  It wasn’t the resistance of the steering lock but something else.  It seems intermittent but that first few tries were worrying.  I tried the spare key and that was just the same on the first go but was better later, but then the main key was also working at that point.  I don’t want to get stranded so need to get whatever it is fixed.
thanks in advance
1999 T registered Jimny. Early G13BB SOHC engine.
19 May 2023 09:59 #249172 by Lambert
Replied by Lambert on topic Steering lock query
I'm not aware of anything in particular, have you tried either some graphite or other dry lubricant?
20 May 2023 07:57 #249191 by Paul4A
Replied by Paul4A on topic Steering lock query
The key isn’t stiff to turn in the lock when it does work so I doubt it’s a lubricant issue.  I suspect something mechanical, like tumbler or the steering lock jamming.
20 May 2023 09:13 #249192 by GWFBrown
Replied by GWFBrown on topic Steering lock query
Have you tried turning the steering wheel at same time as turning the key ?
Gordon
31 May 2023 15:28 #249366 by Paul4A
I did try that as I’m aware that the steering can lock the column making it difficult to turn the key.  But, strangely the problem hasn’t happened again since so I’m just being careful for now and hoping it doesn’t occur again.
Thanks for the comments
Paul
Time to create page: 0.164 seconds
