Jimny 1.3 non vvt to 1.6 non vvt conversion
15 May 2023 21:46 #249127 by Stevekennedy
Hey guys I’ve got a 1.6 non vvt liana engine to pop in the jimny.
what parts do I need to swap over? complete list please guys. Any help is greatly appreciated
16 May 2023 03:27 #249128 by Lambert
It's basically a long block swap. Everything else is retained. There's information in the Jimny information section on the top banner.
16 May 2023 08:34 #249133 by Dured
I think this has been discussed in great detail here and on a certain Australian forum, probably search by key words "Jimny Conversion M13 to M16"
But I swapped over: block, head, injectors, intake manifold with TB (except the ICV). Rest is jimny from m13a: Dipstick, rocker cover, sump, oil filter stud, ICV, Exhaust manifold, spark plugs, coils, flywheel etc.
I would suggest replacing engine and gearbox mounts since engine and most likely gearbox will be out. Maybe clutch as well if you see its below 50%.
Time to create page: 0.203 seconds
