JB74 Alternator Whining
17 Apr 2023 21:06 #248669 by Miownway
My 2022 JB74 alternator has started to whine, changing tone in relationship with RPMs.  I do not believe that it is belt noise, more towards pulley/bearings.  Less than 40k kilometers and only added a pair of DiodeDynamic driving lights to her. Besides going for a fairly deep swim a couple of weeks ago no other electrical changes made.  Any ideas?  New alternator or a fix?
2022 JB74
K15B w/ snorkel
XTREME OUTBACK stage 1 clutch
Warn VRX 4500 winch
235/75R15
18 Apr 2023 01:08 #248674 by Miownway
Replied by Miownway on topic JB74 Alternator Whining
My 2022 JB74 alternator has started to whine, changing tone in relationship with RPMs.  I do not believe that it is belt noise, more towards pulley/bearings.  Less than 40k kilometers and only added a pair of DiodeDynamic driving lights to her. Besides going for a fairly deep swim a couple of weeks ago no other electrical changes made.  Any ideas?  New alternator or is there a fix?
2022 JB74
K15B w/ snorkel
Warn VRX 4500 winch
235/75R15
18 Apr 2023 06:25 #248679 by Lambert
Replied by Lambert on topic JB74 Alternator Whining
Going out on a limb here but submersion is not good for the bearings especially if it's not particularly clean water. You may be able to get it rebuilt but it's likely going to be just as expensive as a replacement.
The following user(s) said Thank You: Miownway
18 Apr 2023 11:05 #248685 by facade
Replied by facade on topic JB74 Alternator Whining
Depends on whether it is a whine, whistle or a whirring sound. they do whistle a bit when they are working hard.
A whirring sound is probably bearing damage caused by letting muddy water get inside as Lambert says.
It is possible to change the bearings, but can be a lot of trouble so a new one would be required.
In my younger days I took the series III to a quarry play day. I happily drove through a flloded hole that was so deep I had to wait until enough water got inside for it to sink so the tyres would grip and I could drive out.
I felt particularly pleased with my driving skills that day.
I was less pleased the next weekend when I found that the alternator was seized, the windscreen washer pump was seized, the heater fan was seized and the starter motor brushes were jammed with silt.
Now if the water is deeper than the tyres I drive round it, a half hour diversion is better than the time and expense of sorting out the damage.
18 Apr 2023 12:44 #248688 by Miownway
The lesson has been learned! TicToc never shows "The-Next-Day" videos
2022 JB74
K15B w/ snorkel
Warn VRX 4500 winch
235/75R15
20 Apr 2023 00:31 #248720 by Miownway
Thank you Lambert and Facade for your guidance and input. I rolled up my sleeves today and took the belt cover off. Before I started loosing bolts I thought I would check again to see where the whining was coming from. Using a long handle screwdriver, I started with the alternator, placing one end on the component and the other to my ear, trying to isolate the noise. Alternator: no noise, Water pump: no noise, Idler pulley: squealing like a stuck pig! Several hundred dollar repair job was quickly reduced to less than 20 dollars.
Lessons Learned: 1- Stay out of deep water 2- dubble check before taking things apart.
2022 JB74
K15B w/ snorkel
Warn VRX 4500 winch
235/75R15
Time to create page: 0.168 seconds
