New Alternator Belt/Q about kingpin
17 Apr 2023 14:41 #248656
by Abudougal
Replied by Abudougal on topic New Alternator Belt/Q about kingpin
Well at least you've got the best colour one anyway..
17 Apr 2023 17:00 #248660
by facade
Replied by facade on topic New Alternator Belt/Q about kingpin
Yes 4pk is the rib type and 835 is the length, so an 836 will fit, but you may run out of adjustment a fraction early when it wears. Going smaller is a bad idea as you can't get the belt on!
The number will be printed on the belt, it usually stays on the alternator belt as nothing rubs the outside, The tensioner rubs the writing off the PAS belt.
Just check what is fitted now, and where the adjustment is.
18 Apr 2023 19:46 #248697
by Busta
Replied by Busta on topic New Alternator Belt/Q about kingpin
There's loads of adjustment on the alternator. I run a 4pk850 as it's the same size as the power steering belt. Anything between 830 and 850 will be fine. I think they come with an 833 when new. Aftermarket belts go up in 5mm increments so 835 is the closest match.
Time to create page: 0.262 seconds
