New Alternator Belt/Q about kingpin
- manyskills
Topic Author
17 Apr 2023 08:41 #248646
by manyskills
New Alternator Belt/Q about kingpin was created by manyskills
Hi All,
I am trying to find an alternator belt. I can't see one on the bigjimny webshop, only the PAS belts.
I'm looking on eurocarparts, but the belts they are suggesting don't match up with the code on the wiki page: 4PK 835. Can anyone advise please?
My kingpin bearing has also gone, so need that replacing. Should I just do both sides even though on the drivers side has failed? I'm looking at this kit , do I need anything else while I am ordering?
Thanks!
Cerys
Thanks!
Cerys
17 Apr 2023 09:06 #248647
by Abudougal
Replied by Abudougal on topic New Alternator Belt/Q about kingpin
Someone linked this to me when I was looking for belts, hope it helps.
www.bigjimny.com/mediawiki/index.php/Drive_belts
17 Apr 2023 09:19 #248649
Replied by yakuza on topic New Alternator Belt/Q about kingpin
Yes, buy that kit. those bearings and parts have good fitment, high quality. And the bearings got the small rubber part that seal it a bit better, cheap alternatives may not.
Funny: A friend of mine did a LJ80 king pin this weekend, same bearings on king pin from Jimny gen 1 and thru gen 3
- manyskills
Topic Author
17 Apr 2023 09:43 - 17 Apr 2023 09:44 #248650
by manyskills
Replied by manyskills on topic New Alternator Belt/Q about kingpin
@abu Thanks, yes I've been on there. That's where I've got the part number from. It's just that eurocarparts is suggesting that part doesn't fit mine, so I'm a bit confused about it.
@yakuza thanks for confirming. And is that all I need? aside from oils and grease.
Last edit: 17 Apr 2023 09:44 by manyskills.
17 Apr 2023 12:02 #248651
by Abudougal
Oh sorry bout that, the guy did explain to me, I think the first bit of the number corresponds to how many ridges are on it - usually three or four and the other bit is the length, I was told if the length is just a bit out no bother as the tensioner will take it up but I'd double check this with someone more knowledgable than me before going for it:)
- manyskills
Topic Author
17 Apr 2023 14:30 #248655
by manyskills
Yes I've read the same. I can get hold of a 4PK836, and to me I'm thinking what's 1mm? but I'm no mechanic haha
Time to create page: 0.337 seconds
