Cutting a hole/ square for easier fuel pump replacement
08 Apr 2023 21:30 #248448 by Adr1an
 After much fiddling with reverse polarity, repeated impulses, rubber mallet knocking to the bottom of the tank etc I'm out of ideas about  resurrecting the fuel pump, so will have to replace it. Makes no sense whatsoever to me to remove the tank for this, so I intend to cut a "window" on the car floor.  But the gap between the tank and the car floor looks really small and clearly a lot of care is needed to avoid pinching the hoses etc.
 How would you go about cutting the car floor? Thanks a lot for any help :)
08 Apr 2023 21:58 #248449 by jackonlyjack
1mm slitting disc on a grinder
Slide a thin piece of plywood/sheet steel
Between tank and floor
Or slitting disc in a dremel tool
Also have a look and do a search in the search bar I believe other members have cut a flap/hole previous
Time to create page: 0.169 seconds
