Re:Brake Pipe
06 Mar 2023 18:53 #247933
by PeterH
Brake Pipe was created by PeterH
Got an advisory on a rusty brake pipe. I've got a flaring tool so will make my own. What is the size of the pipe? I guess it's metric.
06 Mar 2023 21:21 #247936
by gv42
Replied by gv42 on topic Re:Brake Pipe
3/16th I think
Jimny 2003, and 2013
06 Mar 2023 21:58 #247937
by LesNewell
Replied by LesNewell on topic Re:Brake Pipe
Yes, pretty much all cars use the same size pipe. I'd recommend cupro nickel pipe rather than copper. It is tougher and less likely to crack. You do need a good quality flaring tool to flare it. Some cheap tools struggle with it.
07 Mar 2023 00:24 - 07 Mar 2023 00:24 #247939
by JBradders
Replied by JBradders on topic Re:Brake Pipe
While we're talking brake lines, does anyone know what thread Jimny brake bleed screws are?
I need to replace my brake lines this year so will be fitting speed bleeders while I'm doing it. Would be nice to know what size to get without having to remove the old bleed screw to double check.
Last edit: 07 Mar 2023 00:24 by JBradders.
07 Mar 2023 15:02 #247948
by PeterH
Replied by PeterH on topic Re:Brake Pipe
Thanks guys.
I've just had a look. It's the back end by the fuel tank of the long front to rear.
Looks as though it will be fun to replace.
07 Mar 2023 18:36 #247954
by LM42
Replied by LM42 on topic Re:Re:Brake Pipe
M10 x1
The following user(s) said Thank You: JBradders
