Engine cut out and warning light with padlock through it.
- jim pask
3 years 9 months ago #247440
by jim pask
Engine cut out and warning light with padlock through it. was created by jim pask
Hi, my 2000 jimny cut out today after running a bit rough, the dash warning light with the car and a padlock came ( left side of instruments) , it started again after a few minutes. I cant seem to find what the warning light means - any idea ?
Thanks in advance
Thanks in advance
3 years 9 months ago #247441
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic Engine cut out and warning light with padlock through it.
I believe this is the immobiliser. Cheers
3 years 9 months ago - 3 years 9 months ago #247442
Replied by yakuza on topic Engine cut out and warning light with padlock through it.
Try the spare key if you got one. could be the chip inside the key lost its adress in the ecu or the antenna and amplifier beside the ingnition lock is bad.
there is no stand alone immobilizer on these cars, it is integrated in the ecu. could also be the printboard in the dash cluster that has some malfunction. after swapping my dashboard cluster for other reasons I have not had to reprogram the immo-chips to the ecu anymore.
(edit: and the battery oin the key fob (if you have one) has nothing to do with this it is just a door lock remote. The immo-chip does not need a battery, it is a RFID kind of thing.)
Last edit: 3 years 9 months ago by yakuza.
Time to create page: 0.104 seconds
