31s and transfer case upgrade
- Jimima
07 Feb 2023 19:17 #247419
by Jimima
31s and transfer case upgrade was created by Jimima
Hi guys
new to the forum but long time follower. Im seeking clarity on replacing the chain drive/push button transfer case in aid of allowing bigger tyres, probably 31s, and lower low ratio gearing. Jimny is used 99% off-road and only sees the tarmac on its way to local 4x4 trips and sometimes when our daily’s are having services etc. I know this subject has been done to death but cant find all the info i need in one place.
As I understand you get a sj413 transfer case and some of the shafts, tear it down and reassemble it with the new mounting bracket and a trail gear lobster kit.
my jimnys a 2014 m13a manual currently with Maxxis mudder 753 215/75-15 muds
ROH 15x7 black trac steel 0 offset
Dobisons 2 inch lift
Dobisons castor correction
Tough dog steering damper
Zukparts rear shock relocation brackets
ARB diff breather kit
Zukparts transfer case mounts
Zukparts transfer case armour plate
Zukparts radius arm protection
ARB onboard air compressor
Optima yellow top battery
Custom snorkel/airbox
runva 9500 winch and homemade winch plate
- Thank you received: 2004
07 Feb 2023 20:27 #247425
Replied by Lambert on topic 31s and transfer case upgrade
If you look in the information section on the top banner there's a list of all the various ratios used in the various models and markets. Basically you have 1 to 1 high at the moment and will benefit from 1.3 to 1 for 31s. This either means finding a push button case out of an automatic or fitting an earlier lever action box. That or as you suggested finding an SJ box and doing a mini lobster.
- Jimima
08 Feb 2023 01:28 #247432
by Jimima
Replied by Jimima on topic 31s and transfer case upgrade
Thanks Lambert, i want to move away from the chain drive transfer. When you say an sj box do you mean a 410 or 413 and a “mini lobster “ is just a swap of transfer of the box without changing any internals?
08 Feb 2023 04:19 #247433
That's correct, yes.
08 Feb 2023 08:28 - 08 Feb 2023 09:23 #247435
Replied by yakuza on topic 31s and transfer case upgrade
For me doing much more than 1% on road I found that the total build process and what revs I ended up with did not make a SJ lobster case a good alternative. The gears are very different on the 2005 and newer compared to the older Jimnny.
I used the grimjeeper online gearing calculator to see what revs I would get at various gearing alternatives and different tire sizes. i did not plan to go to 31" but 29 or 30 maybe sometime but still. and the amount of building needed with making a driveshaft and the cradle and mounts and most likely also change the axle gearing, it was too much work. And I even got the SJ case and the drive shafts in my garage.
I changed the gears in my original case. But that said, the noise from the chain does bother me a bit.
For me on 235's that is, driving 8-10 hours to get to the offroad sites :dry:
Still I would recommend anyone doing tire or gears to check the figures thoroughly to avoid coming out with a bad result.
www.grimmjeeper.com/gears.html
put all your own data in there and see.
Last edit: 08 Feb 2023 09:23 by yakuza.
- Thank you received: 706
08 Feb 2023 09:35 #247436
Replied by jackonlyjack on topic 31s and transfer case upgrade
I'm sure if you swap R72 gearbox for an R7ME
Then fit sj 410 transfer you will be good for 31's/32's
Time to create page: 0.090 seconds
