Coolant level dropping
26 Jan 2023 09:42 #247181 by AJ
Replied by AJ on topic Coolant level dropping
Thank you Soeley, much appreciated. I have a feeling you may be correct and that its going to prove to be a pinprick type leak that is going to be both difficult to find and sadly very expensive to fix. I have checked to see if I can see anything whilst she is hot as soon as I get home after a run but so far to no avail. I'll post here if I make any progress in finding the leak but if anyone has any ideas on tracing it I would be very grateful if they would share their thoughts.
26 Jan 2023 12:37 #247185 by Scimike
Replied by Scimike on topic Coolant level dropping
Hi AJ,
Must admit your comment about using UV made me look and yes, you can find the leak with a UV system.
Not that expensive and easy to obtain fluid / kits on the net.
One such kit
Check this out! amzn.eu/d/eDV059c
Got to be worth a shot if you can't see the leak.Best check engine first with UV light just in case it's covered with invisible messages from Suzuki !
The following user(s) said Thank You: AJ
26 Jan 2023 16:06 #247188 by DJ20
Replied by DJ20 on topic Coolant level dropping
Is it worth just changing the radiator cap ?
27 Jan 2023 11:51 #247198 by AJ
Thanks again Scimike, very much appreciated. I have a couple of UV torches on order for different projects that will hopefully arrive tomorrow so I will then, hopefully, be able to scan the engine bay to see whats there, clean up if needed and then wait to see if anything new appears. I think the coolant contains Fluorescein, the stuff I got to top up with certainly does, so even if it dries on it should show up under a UV light source if any is escaping from the system. Thank you for the link will keep that noted if I need it, may help someone else in the future too. Thanks again for your help.
27 Jan 2023 12:04 #247199 by AJ
Thank you for your suggestion DJ20, very much appreciated, now I have topped the system up will keep the cap in mind if I cannot find an obvious leak elsewhere, would be wonderful if its something as simple as that. Many thanks.
21 Jan 2025 10:38 #259170 by pavlo_kosiakin
Hi. Have you found what was the cause of leakage? I bought my own brand new suzuki jimny in april 2024 and since then coolant level is droping slowly. Now I have about 10k km on my odoment and cooland level approaching LOW mark
Time to create page: 0.370 seconds
