Coolant level dropping
25 Jan 2023 19:09 #247170 by AJ
Coolant level dropping was created by AJ
Hello all, first time I have had a problem with my 2019 Gen 4 Jimny but a couple of weeks ago I noticed the coolant level was lower than I remembered, checked again today and the level is definately dropping, in the expansion tank its now just above the lowest of the three level markings. Have spent considerable time looking but cannot see any obvious leak. Have checked the oil both on dipstick and under filler cap and it looks perfect, no sign of mayonaise or anything to suggest water is getting into the oil. Heater works perfectly, car runs  and starts perfectly as always. Any ideas on where to look for a leak on a gen 4? Have not noticed anything under the car, but she is outside and the ground is seldom dry. To top up would I have to use Suzukis Blue coolant or can another be used to top up with  until I can trace the leak. Would the leak be possibly detectable with UV light from a torch?
Many thanks
25 Jan 2023 20:31 - 25 Jan 2023 20:43 #247171 by Scimike
Replied by Scimike on topic Coolant level dropping
Check it's dropping first. Should stay much the same for at least a month, but always check with a cold engine as the level moves with expansion.
Haven't seen any reports on the G4, so based on the G3 and in theory they can leak anywhere.
Common leaks are:
Have a good look around all the hose fittings, especially the top and bottom radiator hoses.If you can't see anything try again but use paper kitchen towel to have a wipe around and under the bits you can't see. Its easy to see if it soaks up any water, if it does dry the area and try again after a drive to confirm. Check the engine sides and under the water pump, have a wipe around with the paper towel if you can't see.
Look from under the vehicle if you can, it's surprising how water leaks show up better from underneath as gravity puddles the coolant.
If you can take the plugs out have a look at the colour of them. They should all look similar, if one is obviously cleaner than the others it may be worth using a combustion check kit on the cooling system, cheap enough on eBay etc.
An overnight pressure test may also help, but most don't have the kit to do this so maybe time for a garage. I assume it's not in warranty? If it is take it back to Suzuki and let them do the work.
As for top up you could find out what it uses (sorry no spec for G4), colour is not always sign of compatibility. Prestone coolant is universal and they claim can be mixed with all types, I've seen nothing to undermine this claim.
Last edit: 25 Jan 2023 20:43 by Scimike.
The following user(s) said Thank You: AJ
25 Jan 2023 21:26 #247173 by AJ
Replied by AJ on topic Coolant level dropping
Thank you Scimike, much appreciated, the coolant specified is Suzuki LLC Super Blue which appears to be an Ethylene Glycol non-silicate type. The manual warns about using different types of base coolants, unsure what 'base' means. The level is definitely dropping, its only a few mm in the plastic expansion tank after 300 miles or so but its now near the lower level so need to top up soon.
I'll certainly have a look from underneath as soon as its dry and try the paper towel to see if that detects anything. I have also noted your advice to check the plugs etc but hopefully as the car has only done 21K miles and has had every service done on time by a Suzuki dealer and has never been abused nothing serious will show up. Is there a way to easily get to the heater matrix and its feeds to check around that?
25 Jan 2023 21:58 - 25 Jan 2023 22:04 #247174 by Scimike
It's possible the heater matrix may smell of antifreeze if it's leaking as it warms up. It's also possible your carpet could be damp, but very difficult to prove this time of year unfortunately. They are historically very difficult to get at, can't see the G4 being any different.
Interesting that the antifreeze is reported as ethylene glycol, that tends to be the older "classic" antifreeze. Propylene glycol tends to be the modern stuff as it's a low  toxicity,  ethylene glycol is poisonous. That's the base they are referencing.
Halfords or a good local auto shop should be able to provide this, it's nothing special. LL is a reference to Long Life, usually 5 years as opposed to 2 years for none LL.
Last edit: 25 Jan 2023 22:04 by Scimike.
25 Jan 2023 22:56 #247175 by AJ
Thank you Scimike, appreciated, your explanation makes perfect sense, can call at Halfords tomorrow to hopefully get something to top up with. Have double checked and the owners manual definitely states ethylene glycol. I can smell something inside the car but unsure if its just washer fluid or coolant, the carpets are bone dry so I am hoping the leak is in the engine bay rather than the Jimnys interior. I'm much more used to older cars and although the Jimny is relatively simple compared to many others its still a lot more complicated than the old stuff I was brought up with and am used to fixing...I still worry about not having a starting handle.
26 Jan 2023 08:07 #247178 by Soeley
Replied by Soeley on topic Coolant level dropping
Also a leak could be from such a tiny pin prick hole, it doesn't leak when the system is cold and only when pressure builds  up as the system gets up to temperature.
It could also be leakingp as steam rather than a drip, dribble or squirt of coolant.
Time to create page: 0.263 seconds
