O2 Sensor issues
- monstarghs
- Junior Member
- Thank you received: 2
20 Jan 2023 09:17 #247033
by monstarghs
O2 Sensor issues was created by monstarghs
hi guys, recently ive had issues with my jimmny bogging down under load and i diagnosed the issue as a dirty IAT sensor cleaned it and the issue has gone away, the main problem is not im getting engine codes for low voltage, high voltage, and slow response codes, has the dirty intake sensor broken my o2 sensor? its only happening sometimes and i cant see a problem with the sensor when i have my scanner attached, super hard to diagnose
- Thank you received: 677
20 Jan 2023 10:46 #247034
Replied by DrRobin on topic O2 Sensor issues
I doubt a dirty IAT sensor (is that the MAF sensor?) would cause a problem with the O2 sensors.
As you have a code reader, can you post the codes you are getting please? It might also help if you let us know the age of the vehicle and if it has 1 or 2 O2 sensors (pre and post CAT)?
Robin
Robin
- monstarghs
- Junior Member
23 Jan 2023 11:13 #247112
by monstarghs
Replied by monstarghs on topic O2 Sensor issues
bah of course when i post about it the issue dissapears, if i remember right one of the codes was a p136? i think, also 2005 vvt version
23 Jan 2023 14:39 #247119
P0136 is 'O2 Sensor Bank 1, Sensor 2 Heater Circuit low'. Jimny's only have bank 1 (bank 2 is if you have a V and two exhausts/CATs). Sensor 2 is post the CAT.
It could have been a bad connection, or might be a faulty sensor. Other possible causes might be a leak in the exhaust or even low battery, but then you can get other random codes outputted.
It is probably worth leaving it to see how it goes, especially if the CEL is now off and the car is running correctly.
