Air Con Compressor
17 Jan 2023 17:51 #246971
by PeterH
Air Con Compressor was created by PeterH
2013 Jimny.
I had a completely flat battery and traced a current draw to the air con compressor. With everything turned off as soon as I reconnect the battery the compressor goes 'clonk' and draws about 2 amps. I've temporarily disconnected it.
Any ideas?
Any ideas?
17 Jan 2023 18:08 #246973
by fordem
Replied by fordem on topic Air Con Compressor
The A/C compressor is most likely a clutch style compressor, and the clutch is controlled by a relay, which is either shorted, or being commanded closed by the ECU.
17 Jan 2023 18:16 #246974
by PeterH
Replied by PeterH on topic Air Con Compressor
Which relay? 2 are in with the fuses and 2 are attached to the side of the fuse box.
I will take a photo tomorrow.
17 Jan 2023 23:06 #246979
Replied by yakuza on topic Air Con Compressor
You should be able to feel or here the relay engaging as you connect or disconnect the battery. Also it will become a tiny bit hotter than the other not engaged relays. and of course check the color of the wires to the Ac-solenoid/magnet and see if similar colors can be found at any relay.
Also if you disconnect the relay and the current stops drawing you found it as well..
18 Jan 2023 16:37 #247000
by Scimike
Replied by Scimike on topic Air Con Compressor
If the relay is faulty it may not "click" if it's welded short circuit.
I've not checked as it's too cold for my old bones, but I assume the electric clutch on the compressor has a connector local to it?
If so you could unplug this to temporarily remove the clutch and see it this is the actual reason for the current.
After this you may still need to find that relay, but at least your battery won't go flat whilst you check.
I could be wrong, just putting a suggestion forward which may help.
18 Jan 2023 21:10 #247003
by PeterH
That's exactly what I did. It's stopped the battery drain so car is usable. Like you I thought I wouldn't hear relay clicking if at fault.
When weather warms up a bit I will try, by process of elimination, to identify which relay it is.
I was rather hoping someone would tell me - so I could go straight to it.
Time to create page: 0.160 seconds
