Jimny Wheel Nuts 2008
- Sirjamesrusty
Topic Author
- Junior Member
- Thank you received: 1
15 Jan 2023 21:59 #246932
by Sirjamesrusty
I'm starting my Jimny experience as a complete novice on a 2008 Jimny VVTS...
Jimny Wheel Nuts 2008 was created by Sirjamesrusty
Hello Folks
I've just tidied my steel wheels up (standard steel jimny wheels from a 2008) I was looking at the shiny silver style wheel nuts to go against the black steel wheels (painted) and just wanted to make sure i get the right ones as there seems to be loads of different options. Will buy from the shop on here if available but just making sure I'm ordering the right ones...Thanks
- Thank you received: 679
15 Jan 2023 22:12 #246933
Replied by DrRobin on topic Jimny Wheel Nuts 2008
Steel and alloys wheels use the same thread size, but it is my understanding that the taper angle is different, although I might be wrong, they might be the same. I think the taper angle is 60 degrees, but Martin will know and probably has them all in stock.
Robin
Robin
- Sirjamesrusty
Topic Author
- Junior Member
15 Jan 2023 22:15 #246935
by Sirjamesrusty
Replied by Sirjamesrusty on topic Jimny Wheel Nuts 2008
Thanks DrRobin! - yes - some of the tapers look like they would slip through the hole in the steel wheel which is what started me off on a confusion run!
16 Jan 2023 08:20 #246937
Replied by yakuza on topic Jimny Wheel Nuts 2008
Original whels and nuts are all the same taper and size on alloy and steel. (Based on experience and my 05 jimny)
However if there is aftermarket nuts or alloy wheels those nuts and or wheels might not fit each other.
The following user(s) said Thank You: Sirjamesrusty
16 Jan 2023 08:28 - 16 Jan 2023 08:29 #246939
Replied by mlines on topic Jimny Wheel Nuts 2008
As above, standard taper size across steels and alloys for a Jimny
I dont stock them (no money in it!) but I have just bought these for our own project
wheelpartsdirect.com/products/nuts/64/suzuki/jimny-mk2/original
Last edit: 16 Jan 2023 08:29 by mlines.
Time to create page: 0.159 seconds
