Rear half shaft removal
31 Dec 2022 16:44 #246600
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Rear half shaft removal was created by me101
Hi,
Happy New Year and all that. Oil seal has given up on the rear axle, and also rear diff seems a bit noisy (think it is the diff), so got the wheels off it, and drums off. Looked to try and get the backing plates off, but the 4 x 12mm nuts that need to be removed are looking like they have never been off. They are too small for a 12mm, and too big to fit an 11mm spanner?? So, can these be left in place and just pull out the half shaft?
Thanks,
Thanks,
01 Jan 2023 15:48 #246619
by Busta
Replied by Busta on topic Rear half shaft removal
Unfortunately not. That plate is what holds the bearing and halfshaft in position. Maybe try a damaged bolt extractor?
- Roger Fairclough
- Thank you received: 225
01 Jan 2023 16:39 #246621
by Roger Fairclough
Replied by Roger Fairclough on topic Rear half shaft removal
First wire brush as much of the paint and rust as possible. If the surface is so badly damaged with corrosion that a normal spanner will not work, first try a release agent and then, if you have them, either a single hex. socket or single hex. combination spanner. The nuts are only tightened to 20 lbs.ft so resistance should be pretty feeble.
Let us know how you get on.
Roger
Roger
01 Jan 2023 19:59 #246625
by me101
Replied by me101 on topic Rear half shaft removal
Thanks guys, will have a look on Tuesday when off - will update!
- Roger Fairclough
02 Jan 2023 14:41 #246637
by Roger Fairclough
Another thing that may help is heat. If you have a pencil point blow torch the carefully heat the nut. The nut expands and the heat will break up the rust so try a suitable socket/spanner as soon as you remove the heat. Make a suitable heat shield to keep the flame where you want it.
Roger
Roger
03 Jan 2023 16:22 #246648
by me101
Done! Plenty of penetrating oil and a decent socket. I was using a socket that fits multiple heads (lots of grooves in it) if that makes sense? I used a different one with only 6 sides and that gripped better. Used a big ring spanner for leverage and managed to remove them. Next task is to work out how to get the handbrake cables off and block up the brake pipes.
Time to create page: 0.098 seconds
