G13BB shutting down
25 Sep 2022 08:31 - 25 Sep 2022 08:32 #245105 by DrRobin
Replied by DrRobin on topic G13BB shutting down
It sounds like the battery has had it. It might just have been the battery but if you have the equipment to test alternator/regulator and check for ripple that would be good.
Often it is the battery that acts as the regulator and stops the voltage going too high. They also smooth out any ripple so a weak or failing battery can then result in a lot of other problems.
Good luck
Robin
Last edit: 25 Sep 2022 08:32 by DrRobin.
  • Carlosbeldia
27 Sep 2022 21:56 #245161 by Carlosbeldia
Replied by Carlosbeldia on topic G13BB shutting down
Generator fixed, cmp sensor was damaged so new sensor, timing checked and resistance changed… everything looks perfect now. Good power, very smooth, really nice fuel economy. Battery is done, have been like 6.000 km getting too much voltage.
Time to create page: 0.198 seconds
