G13BB shutting down
- Carlosbeldia
23 Sep 2022 13:01 #245077
by Carlosbeldia
G13BB shutting down was created by Carlosbeldia
As any love story, not everything is perfect. We are having problems with our Jimny lately. It just decides sometimes to shut off or after some trips just doesn’t start again.
after some minutes it will re start and will go as nothing have happen. We already have changed:
spark plugs
ignition coils
spark plugs cables
fuel pump
checked and changed timing resistance
When the failure appears, radio resets, as if the battery was disconnected. Also, when it shuts off and you try to re start it, it sounds like the batt is down in power (not true, battery is in good condition). When finally re starts, starter motor goes normal, like battery is in perfect charge state.
CMP sensor is a big suspect. When failure happens, we pour some water over it and most of the times it re starts. However, it wouldn’t explain the radio reset or the seemingly “temporary low batt” situation. We bought a new one but came damaged from factory, still expecting a replacement.
Any ideas are welcome.
spark plugs
ignition coils
spark plugs cables
fuel pump
- Thank you received: 2001
23 Sep 2022 15:15 #245082
Replied by Lambert on topic G13BB shutting down
Usually it is the crank or cam sensor that causes it but it's not impossible that you have a bad main earth strap somewhere?
- Thank you received: 673
24 Sep 2022 13:09 #245098
Replied by DrRobin on topic G13BB shutting down
I saw something slightly similar years ago on a different vehicle, it was a fault with the starter motor, whilst the engine was running it would just suddenly spin up, draw a lot of current and cause the engine to stall.
It then needed to cool down and let the voltage on the battery recover before the engine would start.
24 Sep 2022 15:15 #245100
by fordem
Replied by fordem on topic G13BB shutting down
A number of years back, my Grand Vitara was doing something similar - the engine would randomly die & immediately restart, it's a manual transmission vehicle so the symptoms were a brief loss of power and the dash cluster warning lights coming on & going off - it went on for a few days until I drove the car at night, and realized that when it happened, all the lights blinked out and the radio was also going off.
I didn't think it was the battery because the starter cranked flawlessly, so I checked the power wiring from the battery, through the main fuse, tec., etc., etc. - all good, clean & tight.
Put a new battery in and haven't had the problem since and that's actually two batteries ago, so maybe six or eight years.
24 Sep 2022 17:15 #245101
Batteries can sometimes loose material from the plates which can collect in the bottom and short out one or more cells. When they do this they draw a large internal current and it drops the voltage whilst it burn off the material. The battery can get very hot and take a few minutes to recovery. The old trick is to shake the battery to re-distribute the material.
What causes the plates to loose material is often unknown, but over-charging, over-discharging and high ripple (noise) as well as poor regulation of the alternator can all cause the problem.
- Carlosbeldia
24 Sep 2022 23:37 #245102
by Carlosbeldia
Replied by Carlosbeldia on topic G13BB shutting down
Thanks a lot for your opinions. Today I noticed water in the battery and checked the voltage. It’s charging 15-16 volts. It appears this damaged the sensor (checked in another car). Tomorrow we’ll repair the generator and check again. Let you know.
