Fuel tank and range indicator
  • bryanyboy
4 years 1 month ago #245069 by bryanyboy
Fuel tank and range indicator was created by bryanyboy
Hi,
My 2022 GLX M/T shows 2 blocks on the fuel level indicator, and gets down to around 64km on the range indicator... and stays there, and invariably when refuelling, only takes around 30/31 litres?
Am I alone here or is this common?
4 years 1 month ago #245072 by Lambert
My 2018 puts the yellow light on at one block and will usually take around 36 or 37 litres if I left it that long.
4 years 1 month ago #245074 by Soeley
I calculated that when the orange light comes on I have about 1.5 gallons left in the tank, so have gone another 40 miles before filling up. That was based on the tank average of 42mpg.
  • bryanyboy
4 years 1 month ago - 4 years 1 month ago #245313 by bryanyboy
Replied by bryanyboy on topic Fuel tank and range indicator
Thanks Lambert and Soeley, I have not yet seen the yellow/orange light as I fill at 2 blocks with the range eventually getting down to around 25-30 km?
not comfortable not knowing, perhaps I should run her dry with a spare can in the back.
Last edit: 4 years 1 month ago by bryanyboy.
4 years 1 month ago #245314 by DrRobin
The fuel tank is 40L, so always assuming the gauge is linear and accurate (big assumption) 2 blocks left out of 10 would suggest 8L (1.7 UK Gallons), that agrees with Soeley's experience and when you fill up with 31L.
Not sure how many miles per litre you get, but if the range indicator shows 64Km, that is 8Km/L which is probably not far off.
Every vehicle I have owned with a 'digital' fuel gauge or miles remaining has gone down to zero and there is still another 10-15 miles (15-25Km) left, but I don't like to risk it unless I am close to home.
It is not a good idea to run a tank dry, apart from the fact that the deposits in the fuel sink to the bottom of the tank, if the pump runs dry it can sometimes take a bit to get it to fill again or you can get a vapour trap.
Robin
4 years 1 month ago #245316 by saxj
Replied by saxj on topic Fuel tank and range indicator
The Gen 4 fuel light comes on when there is 6l left in the tank. The last block starts to flash when there is 4l left.
Time to create page: 0.098 seconds
