04 jimny 3" lift advice
24 Sep 2022 10:02 #245094 by Mike G
Replied by Mike G on topic 04 jimny 3" lift advice
I recently had the same airbag issue.  Whilst doing my body lift, I had turned the wheel too many times in one direction and pulled the ribbon contacts off.  I took the clockspring unit out, used a lighter to burn back some of the insulation on the ribbon cable and had a go at it with a soldering iron. Keeping the ribbon tidy and loosely wound was a bit of a pain when putting it back together.
It worked for a while, but I will have to fix it again as the soldering isn't very well done and every now and again the light blips on.  If it fails next time I'll just bite the bullet and buy a used one.  But it would be enough to get it through an MOT.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
29 Jun 2024 19:22 #256542 by Scot The Sniper
Thanks for this I get fed up with it amd it sits in my garage time to have another go I think.
Scot
Time to create page: 0.232 seconds
