Tow Bar Wiring Help
4 years 2 months ago #244616 by bryn
Tow Bar Wiring Help was created by bryn
I have just fitted the Tow Trust tow bar which was very easy ti fit. I’m just about to do the wiring and will use the “How to” on the forum  which seems to cover it.
Do I need to fit the audible alarm which comes with the wiring kit and are there any pit falls I need to avoid.
Many Thanks
bryn
4 years 2 months ago #244617 by Scimike
Replied by Scimike on topic Tow Bar Wiring Help
Just take your time and check as you go.
Yes you need the indicator "tell tail" or audible alarm, it's an MOT thing if they ever bother to check it.
If you can solder and heat shrink the connections, if you can't then it's scotch lock connectors which are a bit iffy, so check they actually make a connection before you move on to the next.
Time to create page: 0.075 seconds
