M15a clutch
  • GusBus
4 years 3 months ago #244580 by GusBus
M15a clutch was created by GusBus
Got a jimny that had the m13a engine swapped for a m15a engine from a holden cruze(Australian version of a Ignis) by a previous owner. Looking at replacing the clutch but not sure whether clutch would be different to a standard m13a jimny clutch or would it be the same clutch as the ignis/cruze? Are the clutches different? are they interchangeable? Guessing it would depend on which flywheel the cars using are these interchangeable aswell?
cant really take the car apart to look as i need to keep it on the road so i want the parts reaady so o can put them straight in once shes pulled apart.
4 years 3 months ago #244586 by Lambert
Replied by Lambert on topic M15a clutch
As far as I am aware the type of flywheel and clutch is determined by the gearbox being used not the engine size. Don't take this as gospel though as I have not yet needed to do a motor swap.
4 years 3 months ago #244588 by Busta
Replied by Busta on topic M15a clutch
It will be a Jimny clutch. Swapping the Jimny flywheel and clutch onto the new engine is part of the conversion.
  • GusBus
4 years 2 months ago #244589 by GusBus
Replied by GusBus on topic M15a clutch
Thank you kindly I'll order the clutch Hopefully all goes well
Time to create page: 0.081 seconds
