2006 JLX A/T slipping gears
12 Aug 2022 23:02 #244517
by JC1990
2006 JLX A/T slipping gears was created by JC1990
Hi all, I have an 06 VVT Auto who is playing silly buggers.
Recently started slipping when shifting through gears on cold mornings. Seems to get better when warm.
I have had issues with the well reported output shaft seal leak previously, however the box is full of fluid.
Any thoughts on this, is it just temps or maybe a pressure issue somewhere?
P.S if anyone can post a photo of the AT box fill point that would be great! Manual isn't very helpful.
- Thank you received: 2004
13 Aug 2022 06:10 #244520
Replied by Lambert on topic 2006 JLX A/T slipping gears
First things first have you had a code reader on it to see if it thinks it has a problem?
13 Aug 2022 08:00 #244521
by JC1990
Replied by JC1990 on topic 2006 JLX A/T slipping gears
I haven't and that's a good place to start. I'll pick up a code reader and give it a whirl.
13 Aug 2022 10:08 - 13 Aug 2022 10:10 #244523
by JC1990
Well, the gearbox has completly failed now. Stuck in neutral, with no drive.
Last edit: 13 Aug 2022 10:10 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
13 Aug 2022 10:14 #244524
The most likely culprit would probably be the oil pump in the box. I have no idea what the current price situation is for a new second hand one but a rebuild is going to be several hundred pounds minimum more if you cannot remove the box yourself.
13 Aug 2022 10:19 #244525
Just looking at prices on eBay, holy moly, next to no change out of 1500 quid! I'd be finding a gearbox specialist if I were you.
