any recommendations for the transfer mounts replacement process?
- KitKat
24 May 2022 08:20 - 24 May 2022 08:24 #243432
by KitKat
any recommendations for the transfer mounts replacement process? was created by KitKat
Last edit: 24 May 2022 08:24 by KitKat.
24 May 2022 10:03 #243433
by sniper
Replied by sniper on topic any recommendations for the transfer mounts replacement process?
Very simple job, you can do one bush at a time but the mounts are above the frame so very little risk of anything moving... Spray WD40 on the bolts a day or so before you do the job.... If you intended to do much off road or lane driving, I would consider steel transfer mounts, they are a bit of a weak point.
sniper
sniper
The following user(s) said Thank You: KitKat
24 May 2022 14:43 - 24 May 2022 14:44 #243440
Replied by yakuza on topic any recommendations for the transfer mounts replacement process?
do change the brackets to steel as Sniper says.,
But the so called heavy duty thru bolts with not particularly well fitted rubber bushings from various suppliers is probably the one modification I removed the fastest. noise, vibration, misalignment..
I went back to the original ones. Have seen others use machine mounts from hardware stores or self made that actually fit.
Last edit: 24 May 2022 14:44 by yakuza.
- KitKat
24 May 2022 15:29 #243442
by KitKat
Replied by KitKat on topic any recommendations for the transfer mounts replacement process?
Thank you,
But for now i have the suzuki oem mounts.
sniper:
Can i just remove one by screw out the nuts replace to new one, etc?
I will not have to pull out both residences?
Thanks
sniper:
Thanks
24 May 2022 16:23 - 24 May 2022 16:27 #243443
loosen all three but with nuts still just on to get enough play so the brackets or mounts can be removed and changed. be careful not to damage the wires, there should be enough play in them to change the mounts. By lifting the transfer case with one hand you can replace the mounts with the other. make sure the car is on a safe jackstand and an extra one for safety.
make sure the new mounts are all in place with finger tight nuts before tightening it all down, and you should be ok.
Last edit: 24 May 2022 16:27 by yakuza.
