Engine and windows dont work
- Rotemy
07 May 2022 04:10 - 07 May 2022 04:11 #243241
by Rotemy
Engine and windows dont work was created by Rotemy
Hi every one.
hope the help will came from here.
jimny 2003, 1 3 auto.
before a week the engein start over hot so i did head engine work and put all toghter... i try to start up but the car didnt want to start .... the starter sound good and all the electric system work , also the battery voltage good.
i saw that the windows dosent work... i read on the internet that maybe there is fuse for the ignition and the windows toghter but didnt find him in my car, all the fuse ok inside and outside... maybe there is minus cable that i didnt connect?
Pls, can some one help ?
Thanks!
Thanks!
Last edit: 07 May 2022 04:11 by Rotemy.
- Thank you received: 2005
07 May 2022 04:33 #243242
Replied by Lambert on topic Engine and windows dont work
Welcome to the forum. Issues like this are difficult to solve over the internet but the fact that it did work before you did the head does suggest that you have missed a connector somewhere. The best and cheapest option is to start at the battery and check every connection you can see and also all the wire paths to make sure everything is correct and that nothing is trapped or crushed or otherwise damaged.
- Rotemy
07 May 2022 04:48 #243243
by Rotemy
Replied by Rotemy on topic Engine and windows dont work
Thank for the welcome and thanks for the answer... i will check all the connection again. I guess its maybe some minus that i didnt connect as its was..
I ask myself if there is connection that respansebole for the windows and ignition ?
07 May 2022 06:36 #243244
Often with the windows it is because someone has accidentally pressed the lock button on the drivers side control switch?
Time to create page: 0.364 seconds
