How long before I fry the clutch?
15 Apr 2022 12:44 - 15 Apr 2022 12:50 #242913 by marbit37
You are completely right, don't know why I didn't specify the full dimensions, 235/75/15.
Update: I tend not to ride the clutch often, I used to before but forced myself not to do it. And as for the hills I happen to drive in a hilly terrain.
Last edit: 15 Apr 2022 12:50 by marbit37.
15 Apr 2022 13:09 #242914 by fordem
A 235/75R15 would be right on the borderline (5.8%) of where I would be considering a re-gear - where I am, I can live with it, since you're in hilly terrain, you might find it necessary - or you might be able to get away with shifting one gear lower down in the hills (second instead of third) - try it and see.
You will be harder on the clutch that I would, but that's because of the hills - if they are steep enough I guess it could become a problem.
The following user(s) said Thank You: marbit37
18 Apr 2022 08:26 #242966 by marbit37
Thanks guys I will try the bigger tires and lift and see how it works. But will re gear eventually soon, maybe also get a throttle controller to help with acceleration.
Time to create page: 0.205 seconds
