How long before I fry the clutch?
15 Apr 2022 11:39 #242905
by marbit37
How long before I fry the clutch? was created by marbit37
Sorry in advance if this is not the correct place or it has been asked before, but I pretty much didn't find a thread where this question is described in detail.
I am bent on putting 235s on my gen4. That includes lifting and re gear, also maybe replacing the breaks. Since this whole project will potentially cost a lot, I am planning to do things step by step.
How long can I go with 235s and lift only before burning the clutch or damaging something? I got 9100 kms on it in this first year, of which 15% have been on the highway, 35/40% off road and the rest city driving. If it's a must, then I guess I could do the lift first and then put the bigger tires and change the gears.
As for why I am doing it, so far I've never had problems with traction, only with clearance in ruts and in deep mud.
15 Apr 2022 12:09 #242907
Replied by jackonlyjack on topic How long before I fry the clutch?
It will depend how you drive clutch wise
will 29's not fit on standard suspension ?
having relatively new suspension fitted i would fit spring spacers/shock relocation brackets (i never usually say this)
but you money would be better spent on gearing
15 Apr 2022 12:12 - 15 Apr 2022 12:15 #242908
by marbit37
Replied by marbit37 on topic How long before I fry the clutch?
They will fit, but they will rub eventually when flexing.Plenty of people have them without lift, but they don't do hardcore off road. Plenty of people also run them without re gear, but this forum has scared me into not doing that
Last edit: 15 Apr 2022 12:15 by marbit37.
15 Apr 2022 12:22 #242910
I have 32's on my gen3 with re gear. recently changed my clutch (not slipping but had engine out)
I have had jimny 5 years so the clutch could have been 10+ years old
gearing is the key to clutch life
15 Apr 2022 12:24 #242911
by fordem
Replied by fordem on topic How long before I fry the clutch?
Saying you want to put 235's on a gen4 is telling us half the story, 235 is a tread width, you could run something like a 235/60R15 or a 235/65R15 and it would be close enough to the original (195/80R15) tire diameter that the gearing would not be affected.
I understand that is not your intent, but you haven't given us enough detail to work with - the only recommendation I could make based on what you've given us is that you'll need a wider rim - the OE rim is a 5.5x15 and the widest tire you can fit (based on the tire manufacturer recommendations is a 215.
There are, at least to me, no "hard & fast" rules on the need to re-gear, I've worked out my own "parameters" which are based on a larger heavier vehicle with a larger engine (Grand Vitara with a 2.0 engine) - anything over 5~6% increase in tire size will make for a noticeable hit in acceleration on the flat, and at that point, if you're frequently in hilly terrain (I am not), you'll be needing to go down a gear lower than you would have on OE sized tires.
Whether or not it will "fry the clutch" is going to be dependent on driving style, and the terrain you're driving. How often do you find yourself in a situation where you need to slip/ride the clutch?
I've been running oversized tires (first 225/70R16s and now 235/70R16s) on the GV for the better part of a decade and the clutch does not appear to be any worse for it.
15 Apr 2022 12:27 #242912
235/75/15 will be what he's saying
The following user(s) said Thank You: marbit37
