Differential oil
05 Apr 2022 17:41 #242752 by gv42
Differential oil was created by gv42
Can you put  80w-90 LS  Limited slip gear oil Differential API GL-5 LSD in  your Diff,,,
05 Apr 2022 18:29 #242755 by Lambert
Replied by Lambert on topic Differential oil
Probably. I take it this is some you have from another project, if so check the expiration date as it doesn't last indefinitely.
05 Apr 2022 19:08 - 05 Apr 2022 19:54 #242757 by gv42
Replied by gv42 on topic Differential oil
Thanks Lambert it's new and I get  20 Liters for £ 42.00p
Last edit: 05 Apr 2022 19:54 by gv42.
05 Apr 2022 19:16 #242759 by Roger Fairclough
Replied by Roger Fairclough on topic Differential oil
Do you already have a limited slip diff? and what oil is in use at the moment?
Roger
05 Apr 2022 19:44 #242762 by Busta
Replied by Busta on topic Differential oil
Yes you can, but that sounds expensive! Unless you have a plate LSD fitted regular GL5 80/90 is all you need and should be cheaper.
05 Apr 2022 19:53 #242763 by gv42
Sorry I get 20 Liters for £ 42-00p
The following user(s) said Thank You: Busta
Time to create page: 0.178 seconds
