Re:Suzuki gen 4 2021 MODEL .low range
- chrisbenadie
30 Mar 2022 11:07 #242575
by chrisbenadie
Suzuki gen 4 2021 MODEL .low range was created by chrisbenadie
Hi
I have the following problem with 30k on the clock
When low range is engaged,and travelling down hill,in 2nd or 3rd gear ,the low range gear lever disengage by itself.
I have tested it with low range 2nd gear and hill Decent ,after a while it disengage.This has happened 4 times already,the dealer said they have never had this problem.Anybody experienced this?
Please help.
Please help.
30 Mar 2022 11:44 #242577
by 300bhpton
Replied by 300bhpton on topic Suzuki gen 4 2021 MODEL .low range
I had issues with mine jumping out of low range. Dealer replaced the transfer box. More info in my thread (sorry can't recall which page).
www.bigjimny.com/index.php/forum/8-my-ji...og-mods-build-thread
- Thank you received: 2004
30 Mar 2022 11:59 #242578
Replied by Lambert on topic Suzuki gen 4 2021 MODEL .low range
Welcome to the forum. It jumping out of range not gear? I assume it is otherwise unmodified no body lift or anything? Usually in the earlier versions this happens because of a body lift stopping the lever from fully engaging the gears. Do you use the lever regularly to keep it free? Do you spend a lot of time in mud that could bind up the linkage/mechanism?
10 Apr 2022 19:32 #242841
by Dan
Replied by Dan on topic Suzuki gen 4 2021 MODEL .low range
Mine was in 1st gear in 4Low with hill descent control switched on and jumped to 4High today. Seems like a relatively serious safety failing if you were on a dangerous drop.
10 Apr 2022 22:06 #242844
by crash486
Replied by crash486 on topic Re:Suzuki gen 4 2021 MODEL .low range
The lever actually moves from 4L to 4H or is it the hill descent turning off because of heat?
crash486 JB74W
crash486 JB74W
11 Apr 2022 14:07 #242855
by Dan
Replied by Dan on topic Re:Suzuki gen 4 2021 MODEL .low range
The lever jumps out from 4low ro 4high all on its own. Was using the hill descent control for a minute or two going 50 meters down a steep gravely track, so it's unlikely to be heat related.
