Strange oil color in the front diff.
- Roger Fairclough
- Thank you received: 224
05 Apr 2022 15:41 #242744
by Roger Fairclough
Replied by Roger Fairclough on topic Strange oil color in the front diff.
The amount of grease that is inserted into the axle housing, oh by the way "challis" is a soft silk and worsted fabric, is 100grammes per side, not a small amount as has been mentioned. This amount is inserted after the axle shaft is placed approx. halfway into position. This means the shaft is unsupported and the grease, having been applied to the rear of the housing will see some of it pushed past the seal as the shaft is pushed all the way into position. Another point is that an 08 Jimny will not have seen a Suzuki franchise for many years and as it has been pointed out the technicians who have maintained the car over the years may well have exceeded the recommended amount of grease placed in the housing and then entered the shaft after applying this extra grease and by so doing pushed even more grease into the main body of the casing.
Now that we have more info. concerning the previous owner and it has come to light that he liked to play in the mud, it has been proposed that water entered the main casing and mixed with the diff. oil but the new owner has said that he checked the axle breather and said that it was working correctly.
So how was the water getting in? If the breather was ok, it wasn't getting in that way so that leaves the knuckle seal and if water got in here it would mix with the grease before it could enter the axle casing and thence into the diff. One thing that wasn't mentioned was whether the oil level was over the recommended level ie did it gush out when the fill plug was removed?
Roger
Roger
The topic has been locked.
- Thank you received: 1976
05 Apr 2022 16:26 #242746
Replied by Lambert on topic Strange oil color in the front diff.
I don't know what vehicle you are thinking of but on a Jimny you definitely don't put grease into any part of the axle before you insert the half shaft into the differential. You leave the grease in the moving parts of the CV joint and there only. You do not put extra grease inside the swivel ball. Believe me. The swivel ball is designed to run dry unlike say a solid axle defender or discovery mk1 which are designed to run in one shot oil or grease. The outer axle sealing surface and seal on a Jimny are not capable of retaining grease, they are dust seals to keep the larger debris out of the CV joint and kingpin bearings. The axle vents are little spring loaded metal caps that are supposed to be pushed closed by water pressure when submerged but are notoriously ineffective hence most people replace them with extensions that actually exit above the expected watermark. With the factory vents it's very easy to introduce water to the axle.
05 Apr 2022 18:25 #242754
by louchy
2003 '53 Jimny JLX Mode
2" Suspension Lift
Modular Steel Wheels + Manual Hubs
BFG MT's
ARB Delete
Breathers (Diffs, Transfer Box, Gearbox)
Raptor 4x4 Snorkel
Jimnybits Armour (Diffs, Transfer Box, Fuel Tank, Shock Mounts, Rad Arms)
Front & Rear Recovery Points
Front & Rear Lightbars
Replied by louchy on topic Strange oil color in the front diff.
Absolutely agree with the above!
My factory breathers were also working as designed, but after a couple of trips including deep water / mud my diffs were contaminated.
Yes the spring breathers are supposed to close themselves when you hit water, but it the diffs are hot they will still try to ‘breath’ through the springs and inevitably suck in some water, and it doesn’t take much water to make the contaminated milkshake you see.
Replace the diff oil, and if you also want to play in water/mud that is above the axles then invest in fitting some proper breather pipe.
2" Suspension Lift
BFG MT's
ARB Delete
Raptor 4x4 Snorkel
- Roger Fairclough
05 Apr 2022 19:12 #242758
by Roger Fairclough
I am going to make an assumption here and that is that the design of the Gen.3 is basically the same as the Gen.4.
With that out of the way I can advise that the official Suzuki workshop manual clearly gives the added grease as weighing 100 grams and this amount is added to the housing after the shaft is entered into the housing but before it is fully pushed into position. This system would allow grease to bypass the seal.
Yes, I agree that the standard axle venting system leaves a lot to be desired and I replaced it on my LC, and if in the future I decide to be adventurous with Tonka I will fit a suitable system to ensure the local water stays outside and not inside, but the author advised that when he bought the car the vents were working.
Roger
Roger
05 Apr 2022 19:35 #242761
It's time to lock yet another thread before assumptions turn into accusations and insults.
Time to create page: 0.567 seconds
