Lifting
  • Camey2006
26 Mar 2022 17:43 #242515 by Camey2006
Lifting was created by Camey2006
Hi,
I’m new to Jimnys but am attempting to lift my one
I have now purchased, +2” springs and shocks and a +1” body lift. Is there anything else that I will need before I begin to lift it (brake hoses, handbrake cables, steering column etc)?
Also I have seen some posts about caster arms, but I’m not sure what these are or if I’ll need them for this type of lift?
Thanks in advance for all the help
26 Mar 2022 19:19 #242516 by Lambert
Replied by Lambert on topic Lifting
You will need extended brake lines with the addition of the body lift. Castor correction is not always necessary depending on how the car drives after the work. Basically it affects the self centering of the steering.
The following user(s) said Thank You: Camey2006
26 Mar 2022 21:06 #242521 by jackonlyjack
Replied by jackonlyjack on topic Lifting
with the 1" body lift no steering modifications are needed
just make sure you can select 4wd low without any interference (stick shift transfer)
